Blitz dump valves
has anyone fitted their blitz dump valves in the same pipes as the stock ones. if so is there a kit i can get or how did you do yours. i do not want them under bonnet. as there aint much room under there and it is looking cluttered as it is. plus there would be more noise :shock: just behind the mesh grill.
Tony,
How's it going fella?? All good I hope!
I've fitted Blitz BOV's under the bonnet and your right there is not much room at all, I had to cut a tiny square out of the underside bonnet cover. I managed to get them in okay and it fills up the gap nicely, couldn't imagine them not being there now!! :D
They are still very loud even in this position, scared loads of people now...... ;)
Pic is in the rides section (I'm sure you know what it looks like!!).........I'm sure it's not a patch on yours either fella!! ;)
Matty.
Tony,
Matty.
hello buddy did you remove your stock ones. and if so what did you do to the pipework one pipe is about 1.5 inch at the back and the other is about 1 inch at the side. with the vac at the top.
