Yay my parts have arrived
My car parts have finally arrived :D
It was like Christmas all over again. Probably better because I knew none of the boxes contained socks of cheap after shave. Everything would be useful :D
So what have I got here.?
A'PEXi AVC-R Boost Controller
Engine Gasket Set
Greddy Intercoolers. Hmmmmm Greddy *slobber*
PCV Hoses and valves, and now O2 sensors (Boring cos it just looks like a bag)
  • Replies 29
  • Views 755
New lifters
Loads of plenum hoses, turbo oil lines, turbo gaskets, dash temp sensor and ECU water temp sensor.
New Engine Mounts
Nismo 555cc Injectors :D
Unorthodox Racing Pullie
New Wiring Harness :D :D
New A'PEXi intake to go on my Dual POP :D
:D:D
Thats basically everything bar a wheel bearing, turbo gaskts, turbos oil lines and other small things.
Stuart
Nice one Stu its gonna be like a new car when its done , how much was the wiring loom just out of curiosity
Ryan
The harness is about $400 I think. Cant remember exactly. Most places in the US sell them, and at that cost if you are taking your engine out, you are silly not to change it.
Is nice being able to move the harness around with out hearing nasty crackling noises. I also thing the quailty of the harness is better than the standard one. The wires seem to be covered more in tape or insualtion and some of the wires seem to be slightly thicker.
Stuart
Stuart
I dread to think how much you have spent mate but once done should be a crackin motor
Ryan
The cost so far is
$4300 on parts from the US (Not including pistons)
£235 Rebore block, polish crank and new bearing set.
£900 on new turbos. Will be good for 18+psi.
£450 on R33 wheels. (4 tyres need replacng)
I am fecking skint!!!!!!!
What has been the delay Stu? How long have these parts been floating around the Globe?
Most of the delay was the intercoolers, it was a long wait for them, plus I kept adding parts on all the time. Then is was forgotten to be posted for 2 days. Then the US customs had hold of them for 3 days, and then they changed their policy or something and then had to have them again for another inspection another 3/4 days
The parts left the US on the 11th so probably got to Liverpool on the 12th/13th. (Plane was going from LA so would have had to stop somewhere else in the US.) And then after traveling 6000 miles in 2 days, it took 4 days to get from Liverpool to my house 30 miles away ;) Probably stuck in customs again.
Bloody US:D,Mine are on their way from Japan. Deal direct with Japan I say makes sense instead of Japan via US then UK,so I will let you know if their postmen are any better;)
Knowing the Japanese it will be in this country 12 hours after they send it. Then the UK postal serice will sit around scratching their arses wondering what to do with it for 5 days.
LOL:D
But whose 5 days are 5 working days and does not include, bank holidays, religious holidays (any religion will do) weekends, thursdays and fridays.
The cost so far is
Stu who did you get to do your rebore balance and bearing set ??
Ryan
Place called weir street engineers in Blackburn. Did a good job too.
The cost so far is
What kind of turbos can you get for 900!!!
Mine are costing £1500 and they're only stage 2s!
Just getting my ones reconditioned but with completely uprated parts. New wheels, shafts 360º bearings, step gap rings, etc etc.
I asked that and he said that he has sold them to people in the UK before and they had no problems. To be honest I think they actually are Jap ones and made for right hand drive and its infact the people in the US who have more trouble fitting them.
Stuart
Nice one :cool:
Glad to see you've done something with the tubs, it would have been sad to stick with completely standard tubs when ya done all this to her.
You'll have to let me know who you dealt with as I'm planning to bite the bullet in November. Got a few bits like intercoolers already but need to assemble every thing before I start.
You too Mac if you cna let me know who, how much and where. I'm trying to get as much info as poss to get the best bits.
Oh ya remember to change your cam belt pully's or she'll scream like a brazen hoare everytime you start her.
Stu,
If you're using standard tubs then the tub gaskets SHOULD be in the engine rebuild gasket kit - unless things have changed since I last rebuilt one (about 4 months LOL) ;)
are they nismo engine mounts or Nissan ones?
Nismo is the way to go.
Stu,
Well I asked that to the people got the gasket set from and they said the gaskets for the turbos where not in the gasket set, and so I ordered new gaskets for the turbos. I now have 2 sets of turbo gaskets as one set is supplied with the set. :mad: There is everything in the gasket set, including sump washer so I dont know why I was told there where no turbo gaskets.
Nice one :cool:
The whole thing was on a sort of a budget. The main reason for the engine rebuild is to get it back to how is should be, by replacing a lot of the components. I could have got larger turbos but then some other part of the engine would have suffered. My main priority was to get the engine working as best as I could, not to buy larger turbos and hope the rest of the engine still works.
