February 23, 200421 yr The stock induction system seems OK but what do you buy that will give you an excellent sound alligned with increased BHP? Budget of £300. :confused:
February 23, 200421 yr The stock induction system seems OK but what do you buy that will give you an excellent sound alligned with increased BHP? Budget of £300. :confused: A'PEXi PowerFlow (IMHO) is the best you can get for filtration quality and increased airflow. It is a dry type filter so no problems with getting cleaning oils on the MAF's hotwire ... And on top of all that I sell them :D Give us a call on 07044016586 if you're interested: £120 delivered to your door. Cheers!
February 23, 200421 yr A'PEXi PowerFlow (IMHO) is the best you can get for filtration quality and increased airflow. It is a dry type filter so no problems with getting cleaning oils on the MAF's hotwire ... And on top of all that I sell them :D Give us a call on 07044016586 if you're interested: £120 delivered to your door. Cheers! Will I have to make any mods to the car or will it bolt/fit straight on?? Will it give any (claimed) BHP gains? Cheers
February 23, 200421 yr Will I have to make any mods to the car or will it bolt/fit straight on?? Will it give any (claimed) BHP gains? Cheers Absolutely no mods required. Remove old air box (can be tricky), remove MAF, bolt on A'PEXi air filter to MAF (all bolts & gasket included in package), re-install MAF and you're done. Time taken: ca. 30 minutes assuming removal of old air box is problematic. Would suggest you reset the ECU to clear any self-learn parameters. Car will then require approx. 200miles to "re-learn" settle down. Can't really give a clear figure on bhp gain as this is dependent on a lot of other factors as well. Basically, an after market induction kit will free up the breathing of the engine (ie increase the amount of air going into it) which will result (from experience) an increase in torque, especially in the mid-range. Best gains to be had if an induction kit is fitted in conjunction with a free flow stainless steel exhaust (principle: what goes in must come out). Hope this helps. Regards,
Budget of £300.
:confused:
