JUN ecu
Hi all,
I've recently purchased a JUN eprom chip for a TT off e-bay and am awaiting delivery, does anyone have any info/specs/reviews for them.
Baz
Hi all,
Baz
I've got a JUN 555 code. Looks OK to use on optimax. Less timing than some other tunes and fuelling not altered much.
Hi John,
Do the fuel/timing maps look ok to run the usual 14-15psi without too much danger of a very large expensive bang? Do you think i should expect the same sort of power gains as a JWT/SE chip or more or less?
Baz
Hi John,
Baz
Not too sure if the one you've bought is the same as the one I have, so I wouldn't like to say. The one I have certainly is.
I can pull the maps off it for a look if you want.
U will get more power than the jwt because it's more fine tune. But if u upgrade u have to send it to jun to reprogram it
