Right, should the fan come on when i start the car ? Cuz mine does, all the time!
Also,should a battery need to be charged wen brought brand new - before putting in the car?
Cheers - Mike
Yes. The fan has a viscous coupling so it runs with the engine.
As for the battery, I guess it depends where you buy it from and how long its been sitting on their shelf? They are usually charged.
Thanks mate! I though the fan might be like that, but had to check just in case!
Cheers - Mike ;)
If you mean the elec fan then it will only run when the engine is getting to hot OR if your temp sensor connection is knackered.
or if you have no ECU map, but that shouldn't be a problem for you .... ;)
