GReddy twin turbo 350z in Banzai
Saw this today.
Spec includes.....TD05H 18G turbos
2 Airinx AY-SB iinduction kits
front mount GReddy 3core type 23 intercooler
GReddy cat back zorst w/ evolution back boxes
e-Manage and Profec e-01.
I was almost impressed until I read "power rated at 334.2 bhp...... @ 5.6psi"
5.6psi??? FFS why not just use a hairdryer?
A single T25/GT22 could flow more air and spool up faster:slap:
Same spec as my 300 then :D
Hopefully you'll be running substantially more boost:D
Just a touch more ;)
Edit to orginal post
"Will be Same spec as my 300 then :D "
Just goes to show they don't make them like they used to :D
sounds like theyve tried to turbo it without lowering the compression ratio, so can only run at low boost
More like they're worried about holeing its dainty alloy block:D
but my main point was, why bother with twin turbos? for the amount of flow they're using a smaller single turbo would surely work better.
sounds more impressive!! :D
Yeah I think the block isn't meant to be up to scratch for higher PSI!
