battery
can u advise on new battery for 300tt 1994 import.
Have been told calcium plates and 71ah 650 ah. What cold start figs should I look for and make/model. Thanks
As far as I know, all car batteries have lead plates, calcium can be added to the electrolyte (or something like that)
If there is a Costco in your area, they sell Bosch Silver batteries at a good price. I bought the most powerfull one they sell, and it was about £39, over 70 ah I believe, with loads of cranking power.
John
Bosch Silver are a good battery, but not the right size fitment for the zed, you can bodge one in, but not sure if the original clamp will fit this.
Paul:confused:
The Bosch ones fit the compartment fine. The are not as high as the old Nissan ones, you just need to add a few washers to the threaded rods, or put a solid wood shim under the battery, works perfect.
John
Most manufacturers use the same numbers,
069 For UK spec (if you fit these to j specs the +/- are the wrong way round!!)
096 or 100 for imports.
I agree, I've got a Bosch Silver in my UK, and it's fit's like a glove.
Didn't even need washers on the tie down.
