protoj ·
Hi Peeps,
A couple of times a year the 200sx club arrange a top speed challenge, which measure 1/4 mile times and top speed.
In the past many Supras have turned up to this event, so this is an excellent opportunity for us all to kick some ass.
Here's the link, but you might need to register on the board.http://www.sxoc.com/vbb/showthread.php?s=&threadid=67222
Last year I was the only Zed, and I blew it up :( , but beat a few cars, so it wasn't in vein.
It would be nice this year to be amongst some more zeds, and of course not blow mine up :rolleyes:
