- Replies 54
- Views 3.6k
- Created
- Last Reply
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Vacuum Metalizing
£250 or (£215 for subscribed forum members)
+ £50 retainer
This price assumes upon receiving the modifies headlights, you will be sending your old headlights to me with no damage to them. I will be sending the headlights out without the 2 metal retaining brackets on the underside of each headlight or the 4 metal clamps that secure the rubber surround(2 small screws to each piece of metal). The purpose of this is to save you money on postage both ways. If you opt to send me your headlights before I send you the modified lights, extra costs will be requested if these metal clips and brackets are not taken off. It also assumes that there are no faults on the headlights and any other repairs with be at an additional cost.
The inserts are proffesionally prepaired and then go through another 4 phase metalized vaccuming processs. Please do not attempt to remove or change the appearance of the inserts by sanding them or by any other method as this could cause problems for when they are going through the metalizing process.
Because of the very nature of headlights, most of you will require them on a daily basis. Hence, when you place an order with me, I send out a completed set of lights. I would like to think that you will get your headlights back to me with in 2 weeks so that that the next batch can be sent off and return you your £50 retainer.
You will notice that the prices have changed since the last time I was offering this service. This is due to the surface of the inserts not being smooth enough to work on and needing to be professionally prepaired.
However, you must appreciate that I am working on second hand parts that have been previously worked on so the finish, although very good, is not always immacualtely perfect. By this I mean that the reflectiveness will always be there, but if there are any imperfections in the plastic, they will appear.
Vacuum metalizing is not like paint spraying. It is about 10 times finer hence the reason for any minute imperfections appearing. Nevertheless, I do always try to provide a decent pair. I haven't had any complaints so far!
Sidelight and Indicator Modifications
Angel Eyes - £80 Ideal for you boys with Viper front ends
Indicators - £70 Ideal for you boys with Viper front ends
Adding an earthing point for headlight - FOC when other work is carried out.
For those of you that are going for front skirts with no side lights or indicators(Viper), I can also provide headlight modifications to incorporate both or either in 5w bulb format or "Angel Eyes".
If you have any further questions, please mail me on cos.theo@mailcity.com.
Cos
P.S. I will also be able to provide brand new lights with the upgrade and repair/replace any broken parts.
