NZR: Any Web Gurus?
I'm trying to upload Gallery (http://gallery.menalto.com/) to my web site and all that happens when I try to load the Installation Wizzard is the following message:
app->devMode) && $gallery->app->devMode == "yes") { error_reporting(E_ALL); } else { error_reporting(E_ALL & ~E_NOTICE); } $GALLERY_OK=false; initLanguage(); ?>
$value) { if (is_array($value)) { foreach($value as $sub_key => $sub_value) { $buf .= "\n"; } } else { $buf .= "\n"; } } } else { $buf .= "\n"; } return $buf; } foreach ($preserve as $key => $val) { if ($key && !isset($onThisPage[$key])) { print embed_hidden($key); } } // String-ize preserve list $preserve = join(" ", array_keys($preserve)); print embed_hidden("preserve"); ?>
I'm not the best at doing this but am i doing something fundamentally and obviously wrong?
Any advise appreciated.
thanks
Tim
I am going along with Dave on that ...
That is what you would get if php wasn't installed ....
If this is on a website, the webserver has to support PHP, which usually comes at a small cost from your web provider. Maybe £5 a month more.
If not look for a free PHP server. There are some around, I think Lycos or Yahoo have one. They tend to be slow at uploading at times because they are so busy.
You can also install apache web server on your PC and the use one of the directories of apache as a mini server. The files must be in this directory to work locally on your PC.
Stuart
Thanks.
The web hosting package I have says that it's PHP4 enabled, is there anyway of checking this?
Tim
guess you will have to give them a ring Tim ..
You could try putting this code into a HTML file and uploading it to the server. If it works then at least you know that PHP is enabled ...
Example
echo "Hi, I'm a PHP script!"; ?>
Chris
phpinfo();
in a file called something like info.php
that will tell you the exact configuration of php
