protoj ·
Sorry to bother people
sadly no, i have not got my z back, and the bloke crashed it. Her did not relised they are not good in the wet.
My site http://www.burf.com has a search engine submit on it at the bottom of the page
this should instantly index the page you submitted so that you can use the search and your page shoudl come up! Worked so far!
I put this here as i no some of you have websites and this may be helpful to you
Thanks Simon
