:confused: Sitting in the car this morning,i decided i want a 2 or possibly 3 guages in a pod mount...Now normally i would not worry about this but i do not want to snap anything so where do you start,,,how do you get the wires down the pillar and then into the dash without making a mess of it ,,,,,help guyz ,,,some direction needed , i`m good with mechanical stuff,,,,,bad with interior plastic:rolleyes:
And is there a way through the bulk head ,,its dark under there,,,:slap: ,,without drilling a new hole:cry: ,,,,help,,,???
There is an existing hole for pipes, its the one used by the bonnet release mechanism.
The A pillar I got is held on with Velcro, and hasnt moved since it was fitted. Looks pretty good too.
However, I wont mention anything about the wires, because I havent the foggiest and got someone else to wire it up :)
Hi Johnny,
I had mine done recently, triple pod which replaces the A pillar from Z Centre. It takes all the wires etc.
But what do you intend fitting. Water Temp, Boost and oil pressure. There are various ways of connecting them all. Do a search on the forum and there is a link somewhere to a website with most of the info.
But if you haven't done it before some parts you will find hard.
Wish you luck.
Geoff.
Thanks guyz , i want two temp gauges , engine and transmission and boost gauge,,,,but ,,,i think i`ll wait till i meet up with some one who has got them ,,,i`ll have a look then:cool:
You can always see mine.
Geoff.
Geoff.
Try zipping up your flies then... :rolleyes:
