Warranty Price/Description
The warranty price is £395 for 12 months cover with 3 months free.
The warranties are through Warranty Holdings, the 'Gold' option that they offer.
Things not covered are;
Cracked cylinder heads and/or failure to valves as a result of carbon build up. Body, paint, glass, interior/exterior trim, ICE or communication systems and connected equipment, catalytic converters, wheels, air bag and system.
Normal 'wear and tear/sevice' items or other components subject to routine maintenance, i.e. plugs, belts, hoses, light bulbs, wiper blades, rubbers, tyres, batteries and exhaust systems.
What is covered;
This policy covers all mechanical and electrical parts including labour to fit them (in a nutshell everything not mentioned above!)
Plus;
Oil seals - Cranckshaft front seal, camshaft oil seal, auxiliary shaft oil seal, differential pinion seal and any other seal or gasket where removal of the engine, gearbox or differential/drive unit is essential in order to effect repair.
Casings - If any of the covered parts fail and this damages the casings, they will also be covered.
Working materials - Oils, oil filter and anti-freeze are covered only if it is essential to replace them beciuase of the failure of a part which is covered under this policy.
Claims limit is the purchase price of the car being covered, i.e. you paid £5k you claims limit is £5k.
Extra benefits;
Vehicle replacement WH pay upto £30 per day (inc VAT) for upto 7 days towards the cost of a replacment vehicle if your vehicle is being repaired under the conditions of the policy.
Recovery;
WH will pay upto £30 (inc VAT) towards the cost of towing your vehicle to the nearest repairer if the vehicle breaks down.
Overnight accommodation and rail fares;
WH will pay upto £60 towards hotel expenses or a return rail ticket if the vehicle brakes down and you are unable to return home. You cannot claim for the cost of food and drinks.
Driving abroad;
The policy is valid for upto 60 days per annum (pro rata) for driving in Ireland and mainland Europe, WH will not pay more than the equivalent UK cost for parts and labour.
Service standards;
The vehicle must be serviced at a VAT registered garage, 6 months or 6,000 miles (whichever is sooner) from the date of or milage at purchase, and thewreafter at intervals of 6 months or 6,000 miles (whichever is sooner) and must consist of:
1. Change engine oil and filter.
2. Check oil levels in the gearbox and differential and top up where necassary.
3. Check coolant level and anti-freeze/inhibitor strength. Top up where necessary.
4. Check timing belt (if fitted), renew if necessary.
5. Brake fluid must be replaced in accourdance with manufacturers recommendation.
The interval from the purcahse date to the first service and the intervals between services must not exceed the stipulated time or mileage by more than 21 days or 500 miles. This time allowance is to facilitate the vehicle owner to make sure services are completed at the correct intervals. If any circumstances prevent the service being carried out at the correct time WH must be informed immediatly by recorded delivery.
Garages;
You can go to one of Warranty Holdings recommended VAT registered garages to have work carried out but you can also suggest a garage to them (I wrote that section, can't you tell!! )
Now the downside...........
Exceptions;
If you don't claim within 14 days of fault happening, it's not covered!
The policy is not covering;
Vehicles used in timed competition or race; or non-standard, customised or modified vehicles (stock spec only then fella's, i'll double check that though!)
No liability for damaged caused by;
Neglect
Corrosion
Any foreign matter getting into or onto a part
Lack of servicing
Effects of over heating, wether caused by an insured part or not.
Freezing
Abuse
No liabilty will be accepted for;
Poor repairs
Incorrectly fitted parts
Faulty parts
Parts not fitted as standard or optional extra fitted by manufacturer.
And that's about it boys and girls.
I've taken a warranty out, I think it's worth the money but that's my opinion.
If your interested leave your name below or mail me on mattylloyd63@hotmail.com and I'll sort you out.
Matty.
Matty,
I'm interseted, but as you say it's gotta be stock, you know the car i'm buying a lot better than me, what do you think????
Regards
Rich
It's stock parts........
I sent you mail BTW.....
Matty.
Nice one:D
Rich
So basically if a part goes and it is a stock or Nissan standard part it is covered, but stuff like larger turbos are not.
If your engine blows you are covered as long as it is not because of carbon deposits. And if you stock turbos seize you are coverd as long as it is not because of objects causing damage.
What about suspention and such. If your stock suspention goes is that covered? What about wheel bearings and such. Does that come under wear and tear or is that a failure?
If some ones HICAS is not working its covered. (I dont have it ;))
If your car is modified. i.e. chip and increased boost, would that not effect the warrany on the engine and turbos?
Stuart
Not covered:
"Effects of over heating, wether caused by an insured part or not."
So... Radiator fails, engine overheats, and is ruined, you only get a new radiator, right???
Also, too many get outs as far as I can see.
and the killer....must be serviced by a VAT registered garage every 6 months, well there are no garages remotely local to me who I would trust anywhere near my zed, thankyou!!!
So I'll decline
Paul N
Service just means oil change really.
Buy the parts yourself and tell them to change it.
Stuart and Paul,
Find a 'good' garage..............if you catch my drift!!
Matty.
it reads like a pretty standard warranty, id like more info though :) its not very detailed ;) someone needs to get typing
Justin,
That is slightly reduced.
Mike,
Did you not read the post above...........whatever is not in the 'not covered' section is covered. :D
My fingers are tired.......:cry:
I thought I had actually desribed everything pretty well.
Matty.
could you type up whats covered in the engine :) thats basically what I want to see, or if they have a website ;)
I've just been reading through a lot of warranties lately,
also will they not cover me because I have a mongoose exhaust? I have a few mods planned over the next few months and I don't want my warranty null and void say if my engine blows up and i have uprated suspension...
actually I just checked my old warranty....... it is through warranty holdings LOL
ill read my manual ;) actually i know it off by heart...
