Windscreen replacement
I have autoglass coming out on tuesday to see if they can repair my windscreen, £65.51 (im not covered by insurance)
In the event it isn't repairable I've been quoted £342.60 for a OEM replacement part, Can anyone recommend a cheaper route :) (its UK glass and I want to keep the blue tint)
Cheers guys.
its a crack from the botton (above the 100mph on the speedo) it extends in a small arc about 7cm, ill go measure it now,
should be repairable mike, is it a recent crack or has it been there for a while? if its old the repair can be more visable.
its 7cm, its about 5 days old :)
I like to get stuff sorted out quick on these cars, heres to them fixing it, if they repair it ill buy some decat pipes ;)
in that case, bring it down to me, ill fix it & you can buy me some decat pipes :D :D :D
Hi,
I had a crack about 4-5 cm, had autoglass out and they said they can only fix chips (they use some sort of resin i think). Cracks need a replacement screen. Also if the crack is near the area around the drivers head it is illegal to drive the car!
Barry
Originally posted by nelsonbd
Hi,
Barry
i can fix cracks ;) (ooh er)
the resin we use is very fine & flows into the crack by capilery action. :)
