pads and discs
I need to get some pads and possibly new front discs for my 91 zed.
Up to now have been using standard TT pads from Nissan ( got at discount through friend ) but too expensive normally.
Did b19rks offer cheap pads etc.? at some time in the past, or has my memory failed me.
Anybody got any recommendations or options.
just want equivalent, or better than standard not OTT upgrade, cost is all important.
Cheers.
:rolleyes:
Hi Ray
You are right, B19rks has offered pads & discs on past forums to us & other bits.
Strano parts do pads (USA)
Past threds or search might give you ideas too!
Hope it helps
Arthur
Cheers.
:rolleyes:
Ray
I am going to be doing a brake upgrade over the next few weeks so will have a set of Brembo disks available , not even covered 2k miles , let me know if your interested
Ryan
ray,
Just a word to the wise mate, some of the NA disks are different thicknessses to the TT, dont ask me which, am still trying to find out
hugh
Ray
...na disks are thinner than tt disks and have a different offset - best source through MJP. I managed to get some from EBC but they needed 3mm spacers. They were cheap enough at about £55 each, but they don't self centre as the spacers prevent this, so you've to be carefull when removing/replacing a wheel.
good luck
Jack
Thanks for replys.
can I put TT discs on, am using TT pads at present.
oops probably not, if discs are thicker, cailper wont fit, -right!
