Is there a conversion quide or article that provides you instructions and what parts you'll need to convert your auto into manual?
Not seen a guide, but try a search on 'manual conversion' and pretty sure you'll find what you're looking for.
Manual Gearbox
Driveshaft
Flywheel (all the bolts)
Pressure Plate
Clutch Disk
Pedals (CLutch and Break)
Clutch Master Cylinder
Clutch Slave Cylinder
Clutch Booster
Clutch Vacuum Hoses
Check Valve
Vacuum Tanks (2 of them)
Clutch Release bearing
Shifter + Shifter Bushing
Holder Bracket
Lower Dust Boot
Upper Dust Boot
Manaul Shift Boot
Shift Knob :)
ย
Here you go
ย
Re I am waitting you to come here in Limassol tonight. Fitos
