Vijays Boost leak Detector
Had a few hours to kill this afternoon so thought I would put Vijays boost leak detector to the test that I bought 4 weeks ago.
The only problem I had was the very short hose on the foot pump so had to put it on a small step ladder as no box was available, anyway took off the oil filler cap and pumped away and could not build any pressure at all, so put the cap back on and four pumps later had built up suitable pressure to find FOUR :eek: boost leaks (including one split pipe at the back of the balance bar).
Fixed 3 of the 4 as the last one seems to be coming from underneath the plenham somewhere.
Had to adjust the boost controller down quite a bit as its making and holding boost much lower down the set scale (SBC-ID) also had to adjust the TPS as the car was now ticking over at 1300rpm instead of the normal 750.
Pound for pound this is one excellent bit of kit and worth every penny :)
Yep, I can get them made up as needed. £25 including delivery.
Vijay
I still can;t get any pressure on mine or James300's nor did I get any on Paul Gunns ?.
I have a electric compressor as well :confused:
Stu - did you try giving the engine a turn over without starting?There was some discussion a few weeks ago about the valves being in an open position so no pressure can build up.
Pete
Vijay
The best £25 I have spent for my Z. Its great. I reckoment people get this.
Stuart
Pete
I must have missed this.
I don't have any problem turning the engine over without starting with my car at the moment, I mean that's all the fooking this does OL
Stu,
Did you leave the oil filler cap on ??
Also I had to take mine to about 13psi before i found the leeks
Yeah oil filer cap is on :confused: should I have taken it off ?
Where's the bloody instructions for this thing LMAO !!!
