Will i be able to fit a 20x8.5 inch alloy on the front of a zed.
Has any1 on here ever done that b4
Any ideas guys
Help needed quick
FAS
i Cant answer your question but i would be interested if you could.
I posted the question what about 19"s but most people said stick with 18"s but i wont be driving my zed very much maybe 1-2000 miles per year so ride quality is not my main issue its all about the look :)
Kirbz
Working on the assumption that the rolling radius, or diameter is going to be as near as dammit the same as the standard wheel then I would say you probably can. You may need to go a fraction narrower, but as long as they make a tyre in the right size then it should be possible. I reckon you will need a 235/30-20 ! Check here :- http://www.mindspring.com/~toy4two/tire.html
Any ideas guys
Help needed quick
FAS
You'd need 205/30/20 to keep the same diameter.
That's a thin aspect ratio!
Ride iffy.
Try the main American site - somebody there might have
done.
You would be very bold to try it!
