Gear stick wobble!!!!
I've noticed when driving over small bumps my gear stick wobbles i think more than normal.
Are there any engine or gearbox mounts that may have come lose i can tighten up??????
Sorted the low idling with the grub screw,also sorted the clutch adjustment.
Seems fine now.
It's probably the 2 plastic bushes that have worn on the linkage of the lever and the gearchange mechanism.
You can get to them fairly easy from underneath and I think they are only a couple of squids from Nissan.
There's also a big rubber transmission mount that might be worn but is unlikely to come loose and would be more noticeable as the gearbox shunting back and forth when you accelerate/decelerate.
do you mean the rear gearbox mount or is there another mount?, manual box of course...:D ;)
The only mounts that hold it all in are the 2 big engine mounts and the rear transmission mount.
They are not cheap either!
Engine mounts $93 each
Transmission mount $79
I dread to think how much Nissan UK want for them.
http://www.courtesyparts.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=CP&Category_Code=Z32-MTR-MNTS
I found one of my engine mounts was completely ripped off when I took the engine out!
After reading up on some poly uprated versions and the Nismo ones it seems the Z is notorious for destroying mounts.
First I'd heard though.
