Where can I get a full metal Rad - and how much?
I need another rad as the plastic end caps have cracked(this is rad number 2 this year!) once more.
So - where can I get a full metal rad from and at what price?
Are there other options like metal end caps fitted to the standard core?
Would fitting a manual spec rad(without the autobox oil cooler) give me better cooling capabilities? Or are the two types of rad just as efficifent(sp?) as each other?
(If I go the manual rad route then I was thinking of getting this:http://www.zcentre.co.uk/performance/perf2/oil_cool.htm)
Cheers,
Trev
I am sure some one sells the rad ends for £30 and you can get your radiator re-cored for £100-£130 or so. You will end up with virtually a new radiator for under £200
