Hunting/cutting out
Not the end of the world just annoying more than anything.
Idles ok when cold.When hot sometimes hunts between
500 and 1000 rpm.
Also ,sometimes when coming to a roundabout or junction
will cut out and stall - always restarts no problem.
Anybody come across this problem before?
Am I right in thinking its the tps?
Anybody?
Mark
Have you done any checks yet? or anything to try and rectify the situation?
My first thoughts would be to clean the TBs.
No fault codes coming up.
Iv`e cleaned all elec. plugs and connectors at front of engine
still no good.
What are TBs ?
Have checked/cleaned that harness looks ok!
Mark
I'd recommend checking all your vacuum pipes. Sounds like one is off. Does it drive ok, with full boost?
ok guys will try lubricating the idle valve.
Throttle bodies are fine - I gave them a good clean.
Devil - I think all vac pipes are ok - cant find any leaking!
Performance wise car is good, goes like ****.
Vac. gauge is working fine.
Mark
