Tyre problem
help!!! i looked out of my drivers window at my front tyre & its turning :( when i looked in the drivers mirror i saw the rear tyre is turning in the opposite direction :confused:
any ideas????
You must have been accidentaly been stamping on the brake and turning the steering wheel vigorously.
I'd say you've gone into HICAS diagnostic mode by mistake ;)
my passenger says the other side is doing the same now.
help!!
This is what as known as a 'push pull' arrangement. It is to overcome the twisting forces experienced by the chassis due to torque. Perfectly normal. If you don't like it, you can always bridge the push pull sensor with a 1Mohm resistor ;)
some of these responses are so techy they go over my head :confused:
