- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Z32 crankshaft is cross-drilled on both the mains and the rod journal. The oil hole on the journal goes all the way through to the other side so you can see through it. This provides oil for 360 degrees of crank rotation because the top main bearing half is grooved. One hole feeds for 180 degrees of crank rotation. As one hole turns to the bottom half of the main bearing it becomes blocked. The other hole on the opposite side gets unblocked and feeds from the top half of the main bearing . It feeds the mains and the rods. As an added bonus the rod journal is cross-drilled as well. This helps high rpm oiling granted everything else is up to par like the high volume oil pump.
It is hard to tell in this picture but the oil holes go all the way through . The oil feed from the main is in the center of the crank
