- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
This is both the problem and the solution. I've gained a lot through using this forum so I thought I'd give a little back.
Two weeks ago I was driving very casually at about 30mph when I noticed a sudden drop in power. When I came to the next set of traffic lights I noticed that the engine was running rough and the idle was low. It sounded like it was not firing on all cyclinders. If you revved it up it seemed to get better above 2000 rpm, but the car still lacked power.
A local garage helped reveal that it was number 3 cyclinder that was not working, but they could not see why. Swapping the ignition coils had made no difference, so I (well, my Dad actually) figured it was the injector.
After taking off the connector to the injector there was loads of green corrosion in there. A quick clean with some electrical cleaner and it was all back running again.
I think I am now going to go around all of the connectors in the engine bay and clean and re-seat them as this seems to be a common problem.
By the way, it's a 1993 UK spec Twin Turbo.
