the hi capacity or hi pressure line that runs from the pumpp to the rack has sprung a leak ........ will not leak uinder normal use .. just when under pressure.
when i was searching for the leak i peeled back the foam which surrounds it .... find a joint ... joint is where the leak is... found it by holding the steering on full lock .....
is there surposed to be a join on this line WTF is it doing there either way ?
i can simply take it to a hydralic shop and get a similar pipe made up pref out of braided hoses !!! end of problem ?
how easy to bleed rack after ?
will the fluid run out of resivoir when pipe is diconnected ... then i have to bleed hicas ?
lots of questions i know
any help much appreciated :)
scottieeeee
