Clanking Noise?
Hi
I dont know if anyone can help me here but im getting a few noises from under the car.
The noises are definately nothing to do with the engine. The noises are related to "road movement" (dropping off curbs, bumby roads). At first i thought it would be heat sheilds because its got an after market exhaust BUT im unsure now because when your sat in the back quite alot of viberation can be felt through the floor. It can also be felt coming through the drivers side floor plan - but this is more of a scraping noise that only occurs over bumps. The noises are very "loose" type sounds.
I thought it may be suspension related but it has aftermarket BILSTEIN all round?
Could all this noise be from the exhaust, its quite a monster
OR, are their any common problems that you people know about??
ANY IDEAS
Thanks for any help
Tom
You really need to get it on a ramp and give everything in sight a push and a pull, untill you do its all just guess work really hth
Probably your splash gaurds have come loose. But as mentioned above get it on the ramps and take a look.
