Front wheel bearings
Hi, can anyone tell me which cars have wheel bearings with 38mm dia inner, 42mm inner dia, and 46mm inner ?
Bought 2nd hand hub with 38mm on
But bearing from amayama are all 42mm
Z centre state 46mm
Totally confused cos I thought all were same size.
Look forward to any help.
Solved by AndrewG
Thanks Andrew very informative,
I bought a spare knuckle took bearing out put new bearing in to find bearing is to big for hub shaft.
i can only assume the spare came off a Japanese car which have the 38mm inner,
And mine being a UK spec tt must have a 42mm. Won't know until I take it apart.
Very confusing especially when I looked on z centre and theirs are 46mm.
It does seem to be awkward buying parts for UK spec cars.
I will keep everyone up to date when I start refurbishment.
Many thanks again Andrew you are a star.
I bought 40210 33p07 from amayama these are 42mm inner diameter.
But spare hub was 38mm so no good , but at least I now know that when I change I can use my existing hub and they should be okay in new bearings.
Every day is a learning day
Thanks Andrew
