Speed signal input to ECU
Hello everyone, this is my first post in the forum as I mostly use Facebook, dare I say forums were a little before my time.  😛
Does anyone know where the ECU(s) pick up the speed sensor signal from? I am wanting to bypass the converter chip and wire it directly to ECU before it has been manipulated by the converter chip.
As many people have stated in the past the speed sensor sends it's signal to the clock and then the clock relays it to the ECU but I'm struggling to figure it which wire it is. If anyone could help I would really appreciate it. Also I don't really fancy fitting UK clocks as many people have suggested.😉
If you are talking about feeding the speed signal directly to the ECU - I don't think that will work. The clocks convert the analogue signal from the speed sensor into a digital signal which the ECU can read. Bypassing your clocks will not work. Regardless - you can find the pin for the speed signal on the ECU here: Z32 Color Coded ECU Pinout.
