Hunting idle when warm
Hi zedders, hope some of you older heads can shed some light on what may be my issue with my Z
Started hunting very badly when engine gets warm, iacv was my first idea, had it off and cleaned up , both solenoids click with 12v and ohm out at 10 & 22 ohms
Maf looks in good shape , tps is in spec also
Only thing that does look strange is on the datascan, the aac reading is on 12% when cold and hot , Initial startup it was at around 36% but dropped rapidly to 12% , so something isn't right but can't use the car as it basically stalls out when warm idle is all over place
I've read up it should be at 15% when warm is this correct?
Any ideas much appreciated guys
