Thought I would post as couldn't find anything about this anywhere online so might save somebody some time.
After doing head gaskets and timing belt car would not start, could not get the timing mark anywhere near, actually sparking on no3 cylinder,ย  about 90' out on cam. Turned out to be ptu connector on the wrong way. The outer connector casing had got twisted so it looked right and the connector a bit loose with age so it slid over the 2 and 3 notches. Easy fix in the end just wish I'd found it before removing manifold and valve cover again and buying replacement cas.
No posts to show
