Auto Box shift solenoids
Nissan have confirmed I have problems with my solenoids in the auto box.
Problem: Car wont drop from 2nd to third gear.
On inspection the
shift A
shift B
Overrun clutch solenoids dont seem to be energizing when energised from the loom
Line pressure solenoid seen to be working OK
Whats the the procedure to follow from here. Do I replace the first 3 solenoids???
She is a Jap spec SWB Jan 1994 series 3 car.
Are the solenoids in the Jap autobox different to the UK spec
solenoid?
Roy
On inspection the
shift A
shift B
solenoid?
Roy
Roy,
Don't mess around with replacing 1 of them. The shift 1/2 and LP solenoids are fixed in the same pack anyway(about $110 from Courtesy Nissan -and 4-5 day delivery). Also replace the faulty one.
"Line pressure solenoid seen to be working OK" Thats what I was told. Its not worth leaving it if you have to drain the fluid and drop the bellypan. Trust me! These degrade and fail over time.
Andy
Cheers Andy
Would the failure of a/b and clutch solenoid cause the symptoms described?
What does the LP solenoid do as a matter of interest
