hi guys so I have a misfire on cylinder 6 (I think the rear cylinder next to the battery ) anyhow been right through it, spark plug is wet whenย i remove it, checked for spark and that seemed a bit weak so I have a s2 PTU on he car but used the adaptor harness from the series one plugs, so I hardwired the s2 plugs to my loom.
I pulled the injector connector gave the injector terminals a clean, measures the resistance and it was 12.3 ohm, however put it all back together still missing, I listened to the injector with a stethoscope and it's working but it hasn't got the high pitched 'ping' of the other injectors, so after speaking to jimmer we both now think it's a faulty injector (lucky I have 6 month mot extension it was going in for test tomorrow) so I'm guessing it's going to be a plenum off job to do this little bleeder. is it worth just replacing all 6 and done with it?
Edited by Black-zed
