hi guys, connected my data scan to the car today to check for error codes, and it's showing det sensor as being a problem. Jeff at zed world bypassed mine around 7 years ago and fitted a resistor in the wiring plug. the resistor is still in place, so any ideas what the problem may be? I cleared the code and it came straight back.
10 hours ago, AndrewG said:
In the first instance check the plug contacts/resistor tails for corrosion. It is also possible the IMΩ resistor has failed (in the heat).
cool another job for when I visit jimmer then lol
So many det sensor faults. Easy to get at with plenum off too.
19 minutes ago, JeffTT said:
Might be the cable back to the ecu now, if your happy to keep the resister in and don`t see why not after this time, the easiest thing to do it fit the resister at the ecu end between pin 23 and earth.
Ece pin out here >>  https://www.nicoclub.com/archives/color-coded-ecu-pin-1990-95-z32s.html
cheers Jeff, I may have a look tomorrow.
just to put this to bed, I found the resistor had come loose in the det sensor connector, so I cut the plug of the det sensor sub harness, soldered the resistor into that and reconnected, I reset the code, started the car a few times and the code hasn't returned.
Edited by Black-zed
