How do i go about lining up a lopsided door?
Hi, can anyone tell me how i can line my drivers door up again, its probably dropped 1/2 - 3/4 of an inch, havnt got a manual! Had a look at hinge and cant work out if problem is there!
D
UK
You had any damage to the front quarter panel ?. Is it sticking out slightly from the door. Thisis usually the problem. Womeone has probably dropped it off the curb or jacked it up wrong at some stage. Check the join to see if it's crumpled.
It could be that the hinge pins are worn/bent and need replacing.
No damage what so ever, how much are these pins Andy?
D
Sorry, no idea. Can't be that much though - even at Nissan prices (famous last words!) ;)
It's probably just wear. Use 0.5mm approx shim (or a couple of oversize washers), between the door and the bottom hinge.
