Bleeding Clutch
Wazzzz uppp !
i blead the clutch on my TT about a month ago after the pedal got soft, i bleed the top, then the slave cylinder, i was able to get a better pedal by bleeding the slave by gravity rather than, opening & closing the vlave while the clutch pedal is operated,
anyways i got a really solid pedal, now it is soft as sh*t again, still works but just not as good, i am going to bleed it again, am i bleeding the system corectly ? or any hints ?
i was told that it works better if the front of the car is higher ? but havent tried it yet ......
Cheers .......
Scottieeee...
Maybe the slave cylinder or master cylinder seals are knackered and are letting air in??? You shouldn't have to do this more than once....
CheerZ,
Andy
