Misfire
It's had a new series 2 PCU that has been hard wired in, 6 new coil packs and 6 new plugs, the Rev counter is jumping around and the hicas warning light comes on after and flashes after about 10 minutes of driving around.
Any ideas?
Much appreciated :thumbup:
After doing the flex plate it all started about one or two outings so changed all items as was going to still miss fire under load
I and the rev counter been jumping up and down since last hers heat wave
Rev counter is fed a signal from the cas unit as is the ecu to trigger the coil packs and injectors, would start at the connection for the cas unit first.
Jeff
Top right hand side of engine round silver with Mitsubishi symbol on it to the right of fan blade hopefully someone will put pic up .
Edited by johnyboy
Thanks guys as plug was lose and now Rev counter and hicas light are good but as always there is still a misfire !!!!!!!!!!!!!
