hi guys after a few small bits if anyone can help (or can give me part numbers), i'm going to be replacing my dash in a couple of weeks, and got a few 'bit's missing so the list
original screws to hold the radio surround (both top & both for the centre bar)
original screws to mount the radio brackets to the dash (i think these are the same as above)
damper for the rear of the glovebox (i think these are separate) as mine is broken
centre console screw covers (the round covers that go in the bottom of the console under the arm rest)
screw covers for the drivers side window switch surround
good condition drivers window switch surround (although i may buy new as they are only £30ish
i think that's it anything i think of/update i'll edit as i go.
Are you sure it’s the damper that’s broken and not the lower retaining “clip”. If it’s not connected at both ends it won’t work. The lower clip isn’t available AGAIK as I needed one myself, I made do with a larger clip and trimmed to size. If it is the lower clip that’s gone let me know and I’ll post out what I used and you can make it fit.
mine is missing the whole top half, i've only got the lower section on the car
Edited by Black-zed
  • 3 weeks later...
bump
still after the glove box damper
screw covers for the centre console (for the bottom of the main cubby box)
screw caps for the drivers window switch/handle
bump
There’s no damper on later cars, so there isn’t one on my 95 breaker, I got and fit one off a 89 for my own car.
I bought loads of cubby screw covers from the USA once, I found that many cars didn’t have and the owners didn’t even realise, so again not on my breaker.
I can however help with the drivers switch, got a few of the covers knocking about, a piece of fuzzy felt goes over did you know ?
Hi yes I did know about the fuzzy felt but it’s no longer available from Nissan. If you have 2 of the window switch screw covers I’m definitely interested also if you have the piece of fuzzy felt. The damper I was hoping to find one before I fully refit the dash but not big issue if not. I did however find on removing my dash I have loads of ‘wrong’ screws in certain locations so just ordered the correct ones from concept z as Nissan genuine doesn’t seem to have them.
You do mean 2 of these ?
I’ll need to keep 2 back for myself.
Not perfect but I guess most have been dug into.
I can send you some cubby carpet for you to cut yourself as well.
Foc , just pm me your address.
top man, yes those are the covers i need, i'll pm you now.
You need part number 96912-30P00
Of course 3 of.
Of course 3 of.
they are showing NLA with nissan
czp are also showing discontinued, i did look at them first as i ordered some screws & fittings for the dash replacement from them
