hi guys go a slight issue currently with my head lights, drivers side dip & main on dim, passenger main on dim & dip is ok, so far i've swapped relays, with no difference, checked i have power to the RH headlight relay and that seems to be ok, if i bypass the relay on the rh headlight it comes to life, if i bypass the switch i can get passenger side to work not drivers, so i'm guessing it's in the wiring somewhere, perhaps a broken wire maybe? i have put new fuses in, only thing i've not checked is the dim relay but i'm not 100% sure that works or has anything to do with the problem. if i switch to main beam passenger main comes to life both drivers beams stay on dim. it's a 1990 jam looking for any help advice please.
now sorted, ran a new from the relay to the switch and it's all now back to life, just got to sort the horn now as that has also stopped working (relay is fine)
so after a little bit of fault finding this morning, i found the cause to the headlight problem & horn not working, i had a targa leak earlier in the year and even though it never leaked on the wiring plugs in the passenger foot well as it had a piece of soundproofing stuck over it, it turns out 2 of the pins in the green connector broke when i pulled the connectors apart, the pins were still in situ but when i went to check continuity i found them to be very loose & wobbly, it turns out they had broken at the base of the pins. at the time i had no idea what these connectors did so as far as i knew everything was working it was only when i went to drive it yesterday i found the faults. anyhow cut the 2 offending wires from the plug and soldered in a new length of cable on each and all is back to normal.
