Radiator for Manual 1990 NA 300zx Z32
Hi Has anyone got a Radiator for a 1990 Z32 Manual NA that needs a new home ?
Many Thanks
Marc
Many Thanks
Marc
Thanks for the replies, just got in after a disastrous day, the garages diagnosis of a pinhole in the radiator (just make sure you keep it topped up until you get the rad for us to fit) has turned out to be what I assume is a water pump failure, I say this as I am no expert but the temp gauge started going over the halfway mark and when I pulled over and opened the bonnet there was coolant coming from the front of the engine under the cover for the cam belt and going all over the cast housing that the two Radiator hoses connect to this is probably not the best description but any ideas confirming or disagreeing with my diagnosis would be gratefully received.
Huge learning curve on these cars it appears, wish I was a bit more familiar
Thank you in advance for all remarks and advice
Regards
Marc
Regards
Marc
