Hi all, I need a known good alternator to suit my 1993 Twin Turbo 300 ZX please, i.e good voltage output under load.
Can anybody help, mine is currently only putting out 11.8 Volts,
Anybody know if the 300 ZX shares the Alternator with another more common Nissan model, ???.
I've got a spare but not sure what model it's off, is there a difference?
NAs are 80amp, tt are 90amp.
It should be off a TT as I got it as a spare for mine. Just can't remember as it was a few years ago.
Are you sure this unit is churning out 14 + volts under load ?? it appears to be somewhat weather beaten
At least its dry, most of them are saturated with either engine oil from leaking cam end seals or power steering fluid from leaking high pressure pipe, actually found them to be very robust, the major cause of failure been water from deep puddles when no under tray is fitted.
Jeff
thankyou ill give it a whirl, how much are you looking for , if it is a good unit ???
Okay mate. Please keep it to one side for me. I won't be able to fit it for a month after discovering the xxxing fuel tank leak. Is that okay.
Hi T Mogsy, just to update, I have had my own Alternator refurbished, So I am no longer looking to Purchase yours, Thankyou for the help and my apologies for messing you around. ill buy you a pint to make up at the next meet.
Sayers
