http://i67.tinypic.com/ddymwp.jpg[/img]"
http://i67.tinypic.com/2nav0a0.jpg[/img]"]2nav0a0.jpg
http://i67.tinypic.com/ddymwp.jpg[/img]"]http://ddymwp.jpg
http://i66.tinypic.com/2mnornn.jpg[/img]"]http://2mnornn.jpg
http://i64.tinypic.com/2w2107s.jpg[/img]"]2w2107s.jpg
The second 300zx I’ve owned, bought at 55k, now at 103k, after 12 years
Generally only run during the summer. currently SORN'd, once it is back on the road I probably will not be able to sell it!
Details / work / things done
Aftermarket turbo timer and fuzzy logic boost controller (Japanese ‘originals’)
Japanese after market steering wheel
Hid dipped beams, in Zedworld modified headlight bodies
25% over sized aluminium after market radiator
Rebuilt manual gearbox 6 or 7 years ago
Differential checked, backlash re-set at same time
Replacement front and rear shock absorbers in the last 6 years
Reconditioned a/c compressor 5 years ago – very effective a/c!
New condenser, dryer and associated pipework 5 years ago
Apexi inlet air filter
Original spec UK wheels (wider ears) refurbed 5 or 6 years ago
Replacement leather seats – minor marks
Rear brake pipes (wheels to anti-lock controller etc) all replaced in the last 6 years
Respray 4 years ago
New plastic scuttle panels fitted at the same time
Rear shock absorbers replaced 3 to 4 years ago
Rear disc replaced 2 years ago
Hicas bypass fitted
Exhaust is stainless exhaust, from manifold all the way back, de-catted.
Front ends of sills repaired
Replacement fuel tank, fuel filler, tank straps
Timing belt and water pump, tensioner replacement this year
Toyo Proxis tyres good tread
99 spec rear lights (bought new so should last)
Aftermarket reversing sensors fitted
Supplied with the car but not fitted;
Caliper relocation brackets to allow 350ZX discs to be fitted to the front
Front turret strut
Rear sill repair sections
Generally only used during the summer, everything works apart from the clock!
Some wear on the drivers bolster. The rear wheel arches will need some work. Hence my buying the rear sill repair sections I intended to sort that out this winter. But too many vehicles, too little time and a need to downsize really mean the Zed has to go. Largely standard but with a variety of sensible modifications it is a very practical car, I commute with it during the summer and rejoice in the beginning of the dual carriageway heading south from Aberdeen on the way home.
Located just outside Stonehaven it can be viewed most weekends. If it does not gain any interest I'm not really worried, with a bit of sorting of the arches and rear sills this winter I'll have another year of howling motoring!
However I really should sell - price now £3250, call Pete on 7853 240122
Edited by Pete54
  • 3 weeks later...
