Me again.
So I have two questions:
RobHowl ·
I wanted to order new discs on my car, I thought I have 16" but after I noticed that I have 17" discs, not original.
Unfortunately on the disc is no ET nr nowhere.
JAPAN RACING
So my question is what ET nr I have to order it?
NISSAN 300ZX TT, 1990
