Seatbelts- not door mounted
I'm after a pair of front belts as I have new door cards and don't want to cut them up and the door mounted belts annoy me.
They must be b pillar mounted, so either s2 or uk model. E.g. Not door mounted.
Cash waiting.
Cash waiting.
Just a heads up, you will need to insert the thread in the door post to match up with the belts, I have done this a few times and its easy, just buy some belt plates that are for rally cars and you can fit them in the post and either tack them there or bolt in.
Like these
http://www.ebay.co.uk/itm/2-X-BACKING-PLATE-HARNESS-EYE-SEAT-BELT-FIXING-STRESS-ANCHOR-SPREADER-FIA-MSA-/322186942825
Jeff
Thanks Jeff, I was going to weld up some plates but this seems much more simple. I assume moving door mounted belts is a no go based on the angle of the belts in the door etc?
I think I may have mine somewhere, removed from my '95, removed as I now have harnesses and if I left them in the car it'll fair an mot,
If you can find them I'll take them if possible.
Believe I've found them, but they are buried at the back of the garage so can't get them out at the moment, I need to move some other parts out of the way but it's raining hard so will have to wait...
Edited by (adl) phoenix
Found time to get them out today
They are not perfect, but we're only removed to fit harnesses.
Could bring them to the agm if your going.
