Front half propshaft na manual
Hi I'm after the front section of propshaft from a na manual its for a swb but I think this section is the same for lwb .can collect Essex area thanks .
No one/ I can't believe there that hard to get hold of . I had trouble getting the rear na swb section but didn't think I'd have trouble with front anyone please I can collect thanks .
Have a look at these pictures, do you have any measurements so I can check, the last picture is from an lwb auto,I should point out that I do have the flange for the prop in the picture,P13-03-16_17-49.jpg
Edited by 300_zedx
Yes I do still need it it's the missing link on my na frame swap .i need the front section and the opposite end to gearbox has a square flange with measures 60 MM. from centre of bolt hole to next bolt hole .the TT one measure 70mm .not sure on length as its still on car but I believe swb/lwb is same length for front section .it needs to be manual into gearbox end thanks .
P13-03-16_17-48.jpgthis is the measurement with the flange fitted 56cm from the centre of the uj to the face of the flange.
Edited by 300_zedx
Hi mate just measured again and that flange you have pictured looks like the right one will this bolt on the TT front section just wondered if the splines are the same .thanks
Hi mate would you sell me just that flange part of propshaft if how much posted to Colchester Essex thanks .
Sorry no, that will leave me with a propshaft with no flange which I can't see anyone wanting, £50.00 for the prop front section I can arrange to meet you around the Dartford area to save postage.,
Speak to Jimmer, Taff - I'm sure he has a newly-made one piece prop for an NA manual SWB.
