Air Con Radiator
I need an air con radiator as i destroyed mine today :tank:
Need An Air Con Radiator TT 1994 or higher
Edited by GeeDee
ah need a TT 1 then, mine is an 89 dos'nt look like its moved in 28 years
I think I have one, remind me on Friday as I'll probably forget and I'll have a look
Think I might have one aswell.. Although, of you've bust the aircon rad, surely you have no gas left??
I didn't think the gas was available for these any longer?
yeah becoming an expert on this bloody radiator was gonna do a conversion to a 94+, but been reading up u can use R437 its a direct replacement for R12 so i just need a 94+ TT air con radiator
Edited by GeeDee
Ah I hadn't read the title properly, the one I've got is probably not 94+ (how could I tell?) and at a guess I think you'll struggle to find one! Do you think you need it for the gas connection? Does that link redwine posted not have a way around that?
yeah theres 2 ways to do as far as i've read so far u get a 94+ radiator(dryer) and plum that in and then regas with R437 its a replacement for R12 the other way is you do it is a conversion u need radiator(dryer),pressure switches, some adapters and oil then u can gas that with R134a, depending on how often u need to regas the conversion will work out cheaper as R134a is a more expensive gas than R437
94+ on the left 89-93 on the right
Edited by GeeDee
lol yeah took me a while the main 1 is the pipe fitting i've ringed it in red
