left hand pod
Hi, does anyone have a left hand pod without damage, if so let me know please,
Sayers
If you get stuck they can be mended with longer bolts and washers of its the top clips that are broke. That's what I've done and you can't tell.
  • 5 months later...
They're only £30.99 new from nissangenuine.com part number 2526740P00
When refitting the hazard switch you must use the correct screw as the screw holes split. Most are as the screws used for this look almost identical to many of the other dash screws except they're about 2mm shorter. So a lot that have been refitted are often refitted with the wrong screw type.
do you know the part number for the right pod too?
[sIGPIC][/sIGPIC]
u got any pics of it :hammer:
