Hello,
ย
I hoping someone who may have torn leather seats from a UK spec Z32 may be willing to remove the heated seat elements from the seats, as I'd like to purchase them. There are four total, two in each seat. I would need all the wiring connectors still attached to the elements and also a pigtail harness from the body side that the element harness plugs into.
Rare as hens teeth mate, better off going for some generic ones from ebay:thumbup:
ย
I know they are. Should've jumped on a set from a while ago. I might have better luck from my buddy in Germany. There are a lot more later model Euro spec Z32's over there than the UK, although still quite rare. Really want a set of the oem pieces. Have everything I need to install per oem spec but the elements.
But surely 25 year old sweaty ass elements are not going to be as reliable or efficient as a set of new ones, they will still work with your oem switches and wiring, its just like an electric blanket lol
ย
Example http://www.ebay.co.uk/itm/2-Seat-Universal-Car-2-Dial-Switch-5-Level-Carbon-Fiber-Heated-Seat-Heater-Pad-/262571046444?hash=item3d2274362c:g:-BkAAOSwdzVXquah
Edited by groover
ย
I know you put that with a little jest Graham but cut down to their minimum they may just fit inside the tab area which is roughly 8cm x 7cm, the warmth transferring through is another matter :)
ย
Here's a pic of my heated ones for reference........
ย
