Improved idle and performance
Hi All,
I want to give me car a good clean. No... I'm not talking about the body work or interior, I mean the engine.
My car is 12 years old now and I would like to start cleaning the connectors and making small replacements as I am running idle at about 1,000 rpm and seem to be getting less than 200 miles per tank even on long motorway journeys. I know I should be at an idle of 750 ish, but I don't just want to turn my idle down as I think this will effect performance (correct me if I'm wrong).
Although after running an ECU diag, I got the all clear code (55). I only ran Mode II checks and will run Mode I a little later.
I want to start by cleaning the connectors for:
coolant temp sensor,
coil packs,
power transistor unit,
fuel injectors,
mass air-flow sensor,
coil packs,
crank angle sensor,
throttle position sensor
Basically all the connector sensors that report back to the ECU. I also want to clean my fuel injector connectors.
Do you think that this will make a lot of difference to my idle and performance or should I replace the EGR, PCV's and Fuel Pressure Regulator and Fuel Dampener as well ?
Any other tips or tricks that you know of could help me out ?
  • Replies 27
  • Views 1.3k
Have a great MANUAL christmas guyZ ;) Just got told today that we're down to skeleton staff after 1 so that's when I go home :D Good job they decided to tell us otherwise I'd have been here till 5 :o
Not long to get p1ssed now :D
CheerZ,
Andy
I got a ext message from the missus at 12:00. She wanted me to get chicken and some brussel sprouts. I finished work at 12:00 but it's 18:00 now and I've just got in.
Dam it's hard to find a chicken. Every pub I went to didn't sell them. I'm all up ith the christmas Spirit now if you know what I mean. I had to go to M & S in the end.
Ho ho ho
