Rear bleed nipples
Hi just refurbished my rear calipers new seals, dust boots and all 4 new Pistons .I want to fit new bleed nipples can someone give me a link to buy new ones there the smaller type nipples thanks .
The calipers are the same as subaru so might be worth searching for those. Would be easier to find due to age
So are the rears are the same as Subaru .I have r33 gtrs on fronts .
Subarus without the Brembo set up use the same brake calipers as our standard set up. Only difference is there's have subaru wrote on them instead of Nissan. Before I upgraded the set up on mine I used to fit subaru pads. Exactly the same only cheaper than searching for 300zx. You get a better choice aswell searching subaru regarding compounds etc
I remember going into Nissan main dealer for some bleed nipples for my Brembo front calipers. I was quoted £92 each at which point I left overtaking Usain bolt.got a set of ford focus nipples for £6 which are exactly the same as the 350z Brembo nipples. Does well to search compatible parts. Oh and another one that springs to mind, the interior courtesy light that goes brown and horrible in zeds is the same as what's fitted in a micra
I used Speed bleeders on OEM rear callipers..... M10 x 1.0 in stainless steel..... worked out about £15 each plus import tax......
I'm talking about the small diameter rear bleed nipples totally different to front .
Hi taff, I just refurbished mine all round and the ones on mine were all the same thread and pitch.... but had different size nipples on the end, from the front ones to the rears....
