New Driftworks Total HICAS Eliminator Kit for Nissan 300zx z32
The Driftworks Total HICAS Eliminator.
We all know how fragile the HICAS rear steering system is on RWD Nissans. If it's not the incredibly weak outer ball joint that breaks, it's the tie rods. Either way you end up with play, causing unpredictable handling and MOT failure.
This comprehensive Driftworks HICAS Eliminator kit removes every part of the flawed Nissan system, replacing it with fully adjustable, heavy duty rosejointed toe control arms giving precise adjustment and confidence inspiring handling.
The kit removes the HICAS steering rack, the tie rods, the tie rod ends and the outer hub end ball joints, replacing them with:
Two very high quality British built brackets, that bolt into existing holes in the rear subframe. (no drilling required)
The tie rods and ends are replaced with a heavy duty toe control arm, this gives full adjustability, and uses high load 3 piece teflon lined Japanese bearings. These are not service items as some other manufacturers use, they are fit and forget self lubricating rose joints specced for the European roads.
The outer ball joint is replaced with an uprated Driftworks Polyurethane bush completing the removal of every part of the HICAS system.
What you looking for Josh? If it's still there I may be interested.. Trying to tidy the engine bay and getting shot of that hicas solenoid thing will be one step!
Already sold :innocent:
